- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello forum, i have a few inquiries to enhance my projects file structure on my iMac and for sharing packages with clients and consultants.
[1]
I create a new layout on my project and number / name it respectively: IA-004 / Main Level.
At some point i change the name of the board to say: IA-007 / Main level floor plan.
The issue is the board name updates in AC but the .DWG file saved still keeps the old name and number. Now i am concerned that if i do go to update the DWG the new name will count as a new path and AC will not register it.
[2]
As it stands the project files get saves with a number and name but i am familiar with exports from AC-Revit that also have a date stamp saved within the name of the .DWG file. Is there a way i can have AC save/publish my DWGs with the current name/time&date stamp saved as the name of the DWG file?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
2. You manually add any date stamps to names of your DWG files, there is nothing automatic in the base program to do it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello, @pendean lets say the layout's name on the project in AC started as: IA-004 / Main Level.
Then i change it to: AID-007 / Main level floor plan. All changes within the AC project (Sheetset).
When i "Reveal in finder" the layout to see the corresponding file on my mac, the name of the file is not the updated one but the old/initial one the file was created with.
And thank you for filling int the time stamp detail.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
A half-dozen screenshots from you would probably better explain it all if you have the time.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I was under the false impression that as i named the file when i was creating it with a title when i change that title within the project it would save a new version of the DWG using that new title.
I am sensing that this is not correct ?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
