maxim_k
en respuesta a: Anonymous
Hi Albert,
Unfortunately AutoCAD for Mac don't have the functionality described in AKN article you mentioned.
But:
- If you have AutoCAD LT for Mac, then the only one way to import/export Layer State is using command line version of -LAYER command:
https://help.autodesk.com/view/ACDMAC/2019/ENU/index.html?guid=GUID-2C75A883-10CA-4B6C-96AC-BCD7A779...
An example of such workflow you can see on the video following the link provided by @pendean .
- If you have full AutoCAD version, you can try to use AutoLISP routine from my blog:
https://macacad.wordpress.com/2011/04/11/layer-states-manager-for-autocad-for-mac-visual-friendly-cl...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
