2233 Vistas, 4 Respuestas
AutoCad for Mac: Architectural units
I cant seem to put my units into architectural units, does anyone know how to do this for autocad for mac?
en respuesta a: Anonymous
Use the Drawing Setup Utility, which is built into AutoCAD Architecture and MEP:
  1. Click the Application icon in the upper left.
  2. Select Drawing Utilities > Drawing Setup.
  3. Under the Units tab, in the Length section, adjust the Type dropdown.
    Drawing Setup Units
RobDraw
You could try asking in the AutoCAD for Mac forum, if that doesn't solve your problem.
Rob
pendean
MAC forum is over here https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
Remember to tell everyone there your exact AutoCAD for MAC year version.
maxim_k
Welcome to Autodesk Forums!
Hi Abdool,
On Mac you can set Units to Architectural with menu Format -> Units:
For dimensions you need to edit dimension style (menu Format -> Dimension Style):
Select dimension style you want to use for dimensioning, use "gear" menu to modify dim style:
On Primary Units tab select Architectural units:
Don't forget to set dimension style you just edited as current:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
