maxim_k
en respuesta a: Anonymous
Hi Eric,
This could be if the lines are not coplanar, that is they have different Z coordinates.
When you look at them from Top view, it seems to you that they intersect. Actually there is no physical intersection.
You can use FLATTEN command to change Z coordinates of lines to zero, or you can select the lines in question and set their Z coordinates to 0 in the Properties Palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
