418 Vistas, 1 Respuesta
Puntero no muestra cuando existe intersección
Por ejemplo, cuando trato de llevar una linea para hacer intersección con otra forma (SIN LLEVARLO A LOS PUNTOS ANCLA F3) (CON F8 DESACTIVADO), no me avisa en qué momento se cruzan o se tocan.
De antemano gracias.
Saludos!
maxim_k
en respuesta a: Anonymous
Hi Eric,
This could be if the lines are not coplanar, that is they have different Z coordinates.
When you look at them from Top view, it seems to you that they intersect. Actually there is no physical intersection.
You can use FLATTEN command to change Z coordinates of lines to zero, or you can select the lines in question and set their Z coordinates to 0 in the Properties Palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
