maxim_k
en respuesta a: UNKNOWN.DESIGN.LAB
When you are working in Paper space, set units to metric, then all prompts will be in decimal units (you can treat them as mm). When you need to work with metric units you also can activate "metric" text and dimension styles, if you need to work in Model - set units to Imperial, activate "Imperial" dim and text styles. No problem at all.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
