- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello Autocad Forum Super Team,
You guys always figure out solutions to my silly problems
As the title implies i am trying to figure out a way to have my paper space units be in mm and keep my model space in inch. Can anyone help me do that ?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi SHAREEF,
Why not?
But what do you mean exactly?
Do you want to have dimensions in Model and in Paper space in different measurement systems?
Please add more details, describe your goal. Why do you need different measurement systems?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello @maxim_k,
Exactly, model space in US customary and paper space in Metric [mm] systems is my goal.
My goal is to draft in model space in inches but be able to draft and edit my template and other objects in paper space in mm.
I tired using the DWG command to achieve this but i am not able to do it correctly if that is the means to do it. If there is another way please point me to it ?
Your solutions are appreciated always !
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Something like this (see attached)
You need to create separate metric text and dimension styles for layout for 1:1 scale.
The only one thing - you have to decide which viewport scale you need to show geometry from Model.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes that is what i want to achieve.
I feel like i should explain what i am trying to do more to get a better answer.
I am trying to design a new title board and i want that one to be in metric (mm or cm) as i am used to working in metric more. I have a project at the moment the requires that i work in US customary units (inch / feet) so i need to have my model space be in inches.
And that is why i posted to ask on how to do this. As it stands my DWG units and insertion units are in inches and my paper space is as well. When i try to alter things in my title board i am prompted to do so in inches. FOr example i want to stretch a rectangle in my title board so the dimensions are prompted in architectural imperial format which i am not used to working with beyond a certain limit of fractions.
It would be much easier for me to have the paper space be in metric and the orthographic stretching, text size, etc be in mm or cm so i can alter them quickly, with ease and precision.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
