maxim_k
en respuesta a: lagitane
Welcome to Autodesk Forums!
Hi Laurie,
Do you have "Display Plot Styles" option enabled in Page Setup? If yes, then you may look at this article:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/linewe...
Does this happen in only one specific drawing? Or you can see the issue in all drawings, even in newly created.
If this happens with all drawings you may try to restart your Mac as the first step.
If restart doesn't help and problem showed up unexpectedly (everything was correct before), you may try to Reset AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
