dennis_collin
en respuesta a: ian.mag
As you are using a Named Plot Style Template (that uses STBs) you need to ensure your Layer settings are set to an appropriate plot style type such as SOLID ,or if overridden via properties.
When using STB's I tend to use a customised copy of the Autodesk-Mono STB file.
If instead you prefer to use the more traditional CTB method of plotting, then use the CONVERTPSTYLES Command
