maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi
You can find PROFILE.AWS file for 2018 version in:
~/Library/Application Support/Autodesk/AutoCAD 2018/R22.0/roaming/Support
folder.
In order to get to PROFILE.AWS location you may use menu Go->Go to Folder in finder (copy the path from this post and paste it to"Go to Folder" window.
So after making changes to workspace you can copy that file to a safe place and then use it when you need to restore your settings - just copy it back to original location from the "safe place" where you saved it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
