- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Ever since I upgraded to AutoCad LT for Mac 2016 (from 2015, I know slow steps forward...) I've not been able to batch print to our network printer from the Project Manager. I am able to print individual layouts separately, and I've been able to batch print to PDF using the same Page Setup. In the same time frame, I also upgraded our operating system from OS 10.10 Yosemite to OS 10.12 Sierra. Does anyone have any insight to what the problem might be? Thanks.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you provide more details about how exactly you are trying to batch publish to network printer (all steps, your workflow)?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've got a Page Setup called "MZA 11x17" (see the first attachment). I can Batch Print to PDF without any difficulty (see the second attachment). But when I try to Batch Print to the printer (see the third attachment), the printer does not respond. I can however, send an individual layout to the printer without any problems. I'll include a forth attachment in a separate post.
I had no problem Batch Printing to the printer in AutoCad LT of Mac 2015 (and OS 10.10 Yosemite). The problems started in AutoCad LT for Mac 2016 (and now OS 10.12 Sierra).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Just for test:
After unsuccessful attempt to batch print from AutoCAD use command VIEWPLOTDETAILS:
What do you see in the Print details window?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
That was interesting.... The ViewPlotDetails (see the second attachment) indicates that the it's not sending the Batch Print to the printer but to individual .PDF files in my Documents folder.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Will report here about results.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Just tried on my side - AutoCAD 2016 for Mac, macOS Mojave, DesignJet 500 attached to network via Print Server.
Everything works fine - I can batch publish to printer specified in Page Setup 2 Layouts:
Even though the 2016 version is not supported on Mojave officially.
So, I think you need to check plot device you are using in Page Setup. When you Publish individual layout - the name of the printer is "HP 5000", but when you Batch Publish several layouts - the name of the printer is "HP_5000". Why?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I don't know about the difference between "HP 5000" and "HP_5000" other than the underscore seems to be just a place holder. I tried to Batch Publish to Printer the same file in AutoCad LT for Mac 2015 and it did print (see the attached).
So it's not the OS per se, but how LT 2016 is communicating with the OS?
FYI, I just tried to Batch Publish to Printer in LT 2017 and it failed (see attached). It worked to Batch Publish to PDF in LT 2017.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Do you use Project manager? Or you simply use menu File -> Batch Publish...
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I use Project Manager. Interestingly, when I tried it in LT 2017, I also tried the File -> Batch Publish with the same result.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you show also Print &Scan pane of macOS System Preferences? How many printing devices do you have installed?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Not sure what you mean by "Page Setup overrides" in Project Manager? I couldn't find any choice or preference in a variety of locations to verify that.
I've got three printing devices installed. The HP 5000 is the default.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
But looks like it is not the case of the issue.
As I wrote before - I don't have problems with your scenario.
Sorry, I don't have any more ideas for the moment.....
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If yes, can you confirm you still able to Batch Publish from it to your network printer?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I do have the LT 2015 version on the iMac and I can successfully Batch Publish to the printer (just not in LT 2016 or LT 2017). I could go back and forth between the versions if needed, it's just a little more cumbersome. Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The same version of Printer software for HP LJ 5000?
The same settings (if any) inside this software?
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
These have all been on the same iMac. I have a Desktop Subscription which allows three versions. I have hesitated to upgrade the OS beyond Sierra because of other software compatibility.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
After a session with Autodesk Support, we found the problem! The Page Setup that I was using was migrated from the AutoCad LT for Mac 2015 version to the 2016. The solution was to just create a new Page Setup with exactly the same settings, even using the old in the "Start From" drop-down window (and if you care, delete the old and rename the new to match the old).
So simple, yet so elusive.
