maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Abraham,
I cannot reproduce your problem on my side.
Here are the steps I do:
- create new drawing (add layers, add geometry you need to it) or open an existing drawing
- use menu File -> Save As...
- In Save Drawing As window: give the name for Template, select File type: "AutoCAD Drawing Template (.dwt)", browse to location where you want to save the Template (if you need to change it), click on Save button
- answer to Drawing Units and Template description prompts which AutoCAD asks when you save Template.
Now use menu File -> New Drawing, browse to the place where you saves your custom Template and select it, select it and click on "Open" button. All layers and objects as well as settings (dim and text styles, etc.) are here in the new DWG file.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
