319 Vistas, 7 Respuestas
01-30-2019
08:47 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-30-2019
08:47 AM
Sauvegardes
Bonjour à tous,
Je suis tout neuf sur le forum car débutant sur Autocad.
Régulièrement je retrouve des sauvegarde de mes fichiers en cours d'utilisation. Ces sauvegardes se terminent par 2, puis par 3 etc..
J'ai désactivé la sauvegarde automatique, avez-vous une idée de ce que ce peut être ?
01-30-2019
08:04 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-30-2019
08:04 PM
Welcome to Autodesk Forums!
Hi Stephan,
Do you have iCloud sync enabled for the folder where you save your drawings?
Maxim Kanaev
Architect
MARSS
Hi Stephan,
Maxim Kanaev
Architect
MARSS
01-30-2019
11:10 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-30-2019
11:10 PM
How did you disable automatic save?
What value has the ISAVEBAK system variable? Type ISAVEBAK at the command prompt and look at the result returned.
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
01-30-2019
11:20 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-30-2019
11:20 PM
Bonjour,
Dans le menu "PREFERENCE","GENERAL", "ENREGISTREMENT AUTOMATIQUE TOUTES LES X MINUTES"
The value is "1" .
01-30-2019
11:27 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-30-2019
11:27 PM
You don't need to disable Automatic save in AutoCAD Preferences, you can leave it ON.
But you need to turn off creating backup copy (file with the name of the currently saved drawing and with .BAK extension) on each save.
How to:
On the command line in AutoCAD for Mac, type ISAVEBAK, hit Return, type 0 (zero), hit Return again. Then ISAVEBAK system variable will be 0 (zero) and creating .BAK files on each save will be disabled preventing from creation of drawing copy with an incremented number appended to its name.
Maxim Kanaev
Architect
MARSS
How to:
Maxim Kanaev
Architect
MARSS
01-30-2019
11:35 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-30-2019
11:35 PM
You are welcome!
Your English is fine!
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
