john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Typically on the Mac side, I see acad.pgp, linetype files, hatch pattern files, perhaps a LSP or two. Perhaps also a font or two which usually resides in the system folder and not the AutoCAD location. You might have some DWT template files that you have adjusted and then also your plot styles (CTB or STB)
If you have not made changes to your shortcuts or installed any linetypes or hatch patterns, I suspect there is not much to migrate.
The big item might be printer configuration files but I recommend rebuilding those for the specific version of AutoCAD you are using.
John Vellek
