01-02-2019
08:50 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-02-2019
08:50 AM
I believe the shapes, which came from Illustrator (after you explode block) are splines.
Have you tried to convert them to poly lines with SPLINEDIT command:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2018/E...
before trying to extrude.
Plus - are you sure you use EXTRUDE command?
Have you trued PRESSPULL?
Can you attach sample Illustrator file, which you are trying to import to AutoCAD?
Maxim Kanaev
Architect
MARSS
Maxim Kanaev
Architect
MARSS
