maxim_k
en respuesta a: LandscapeArchitectFIU
Hi Tricia,
>>>>Is there a method to import the lines weights and types into the layers properties palette in model space.
I'm not aware of such method.
You can use the trick - work in Model space using viewport in Layout. To be able to see lineweights assigned in CTB you need to check "Display plot styles" option in Page Setup for the layout where you will work inside viewport.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
