- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am setting up a CTB line weights file from scratch for a student project. I was originally taught to only use CTB files when exporting my drawings. However, it makes it difficult to draw in model space because I can't see the line weights. Is there a method to import the lines weights and types into the layers properties palette in model space.
I hope this question makes sense. I attached two screen shots.
Or will I need to manually enter line weight and types into both the CTB file and the layers palette? I hope not... !
Thank you for answering in advance.
Sincerely, Tricia
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I'm not aware of such method.
You can use the trick - work in Model space using viewport in Layout. To be able to see lineweights assigned in CTB you need to check "Display plot styles" option in Page Setup for the layout where you will work inside viewport.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Maxim!
This is probably such a dumb question - but I'm going to ask anyway. I'm sure it will help others too. Is there no way to see line weights at all in model space (MacCAD) ?
Tricia
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
so... if I want to see the same line weights in both model and paperspace for a drawing, I'd need to manually set it up both on ctb file and in layers palette. I understand. I was just hoping for a shortcut or download to enter it once.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
...I understand... but it leads me to a different question. For MacCad is it best to set up line weights with color and use the same color for different objects or to use pen styles? One of the reason in classes I used color for objects was because it was easier to transfer it to illustrator to change colors/line weights for illustrations and diagrams.
What would be best practices for setting up CTB files?
by the way... you're awesome!
Tricia
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim Kanaev
Architect
MARSS
