608 Vistas, 12 Respuestas
cant see the right imported text
I have a weird problem.
When I try to open a drawing with text in my language (Hebrew), the text is shown with mirrored english letters.
The same happens when I import blocks with text in Hebrew.
This is a the block looksThis is a the block looks
any ideas how to fix it?
 im using autocad for students
Thanks!
maxim_k
en respuesta a: Anonymous
Hi Etay,
Do you have all fonts used in this drawing installed in AutoCAD on your Mac?
Use STYLE command to open Text Style window and look through all text styles defined in the drawing. If font is missing, then you should see exclamation mark near it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
I see the font and there's no exclamation mark near it
maxim_k
No, it is there:
You need to add gil.shx to AutoCAD. Then you will be able to see correct Hebrew letters.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
You can find gil.shx here:
https://www.saf.co.il/noa/res_1542
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I downloaded all the fonts and add them the shx folder but nothing has changed.
when i go back to STYLE and look next to Gil i no longer see the sign like before, but on the drawing nothing changes.
also, another block does shoe hebrew letters but mirrored.
pendean
Restart AutoCAD yet? Often needed when adding fonts.
en respuesta a: pendean
yes. several times
ok i restarted the computer and now it works.
Another question regarding this matter.
I can find a place to download Ariel Hebrew font for mac anywhere. on autocad website i see a link but its only for windows.
any suggestions?
maxim_k
You can use that font, it should work on Mac too.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
the download is not for a font but for a windows file (i attached it). after installing the file theres a folders with exe files inside
maxim_k
I don't see any attachments.
Can you share the link you used?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
it turned to be another thing then i though.
thanks anyway!
