- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Why in the new version of Autocad for Mac 2019, if I preview a dwg file in Finder with Quick Look I see a low resolution image. In the 2017 version I had hi res images.
What's the problem?
Regards
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi
Quick Look uses thumbnail preview stored inside DWG file to show quick view in Finder.
To get better Quick Look resolution you can adjust two System variables in AutoCAD:
THUMBSIZE2D and THUMBSIZE.
Try to set them as follows:
THUMBSIZE2D=1
THUMBSIZE=5 (or even more, maximum is 8)
Now save drawing and use Quick Look.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This works, but the links you posted are for windows, form mac there are oly 3 possible values for THUMBSIZE:
But despite of this, I can set other values over 2, as you described.
The thing I can't undestand is:
if the thumbs are saved in the DWG file, why after migration from Autocad 2017 to Autocad 2019 all the thumbs of my files had a low resolution? I haven't re-saved them with Autocad 2019...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
...And looks like Help documentation is wrong, in fact you can set THUMBSIZE up to 8.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Ok, but the resolution of thumbs is saved IN the file, so with Autocad 2017 all my thumbs was in high resolution.
After installing Autocad 2019, the first things I noticed is that all my thumbs was in low resolution.
It's illogic, because I haven't open that files and I haven't resaved them with new version.
And now, if I want all my thumbs in hi res again, I must open all my files and save them with THUMBSIZE > 5...?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
AC 2019 has its own new Quick Look plugin for DWG file format and after you install 2019 version Quick Look uses this plugin.
You can check it by executing:
qlmanage -m
in the Terminal app.
Maybe that can explain this. But I'm not sure, because I'm not a developer - I'm ordinary AutoCAD user, just like you are. ![]()
Maxim Kanaev
Architect
MARSS
