maxim_k
en respuesta a: Anonymous
You always should do it manually.
On the other hand if all objects inside block were created on layer 0 and their Lineweight property set to "ByLayer", then you can insert such block to some layer and lineweights of the elements inside block will take Lineweight property from the layer on which they were inserted.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
