maxim_k
en respuesta a: Anonymous
If you want to be able to set Lineweight for block from Properties palette (as you do in your drawing- you set it to 0.05), you need to edit block definitions in Block Editor (double-click on block to open it in Block editor) and set Lineweight for all objects inside block to "ByBlock":2018-12-09_00-38-22.png
Here are some useful links about editing blocks:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2018/E...
I also attached your drawing in which I already modified some of the blocks and set Lineweight property for the objects inside these blocks to "ByBlock".
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
