endare
366 Vistas, 2 Respuestas
Plot using AutoCAD PDF, layout not centred on page
I've just tried to plot a sheet using the settings shown in the screenshot, and I can't get the page to print centred on the sheet without using the 'Window' option, whereas usually I would use layout.  The 'centre to page' icon is shaded out... What am I doing wrong?
thanks,
Nick
maxim_k
en respuesta a: endare
Hi Nicholas,
That is because you print Layout (what to print option), when you select Layout "center to page" turns off automatically.
Please verify that the geometry in the Layout you are trying to print placed correctly on the sheet (not shifted). If it is, then try to recreate Layout completely, may by there is some errors in the current Layout.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ChrisPreece
Hi @endare,
I'm just checking in to see if you need more help with this. Did the information that @maxim_k provided answer your question?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
