maxim_k
en respuesta a: Anonymous
@Anonymous wrote:
The Dis_ command is a command that measures the distance of a line and inserts the distance above the line at commands end. .....
^C^CDIS_;\_J;MC;
There is no such command - DIS_ in AutoCAD.
Do you mean DIM command, which creates dimensions?
Like this:2018-11-27_23-21-28.png
If yes, then you need to fine-tune current dimension style:
Menu Format -> Dimension style:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
