maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Aaron,
You can edit command aliases in 2013 version, but you have to use Textedit application (or some other plain text editor) for this.
You can use menu Tools -> Customize -> Edit Command Aliases (PGP) to open acad.pgp in Textedit app and edit acad.pgp in it. If you edit the PGP file while the program is running, enter RE-INIT and then a value of 16 to use the revised file.
See here:
http://docs.autodesk.com/ACDMAC/2013/ENU/filesACRMac/GUID-D654A057-799D-4B03-878E-882B7A81E6F2.htm?h...
http://docs.autodesk.com/ACDMAC/2013/ENU/filesACGMac/GUID-A37DAD86-971E-4E5E-8D9A-DF03DC315336.htm?h...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
