- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Text Clipping when plotting to PDF in AutoCAD for Mac
While plotting or saving a pdf, the text at he bottom right corner is getting clipped.
Only part of it is getting printed, it happens only with a particular font 'unispace'.
The right portion is getting cut off.
Is there any way I can convert my text to poly lines ? I assume this will solve my problem.
Regards
john.vellek has edited your subject line for clarity: Text Clipping
Landscape Architect
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Clipped, as in you are not allowing for a wider margin and it is cut off? "bottom-right" would indicate that is the issue.
Can you post a screenshot of the problem, or the actual PDF?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @earthsquare,
Which version of AutoCAD for Mac are you using? Can you tell me how you are producing your PDF?
I suggest that you create a named page setup and apply it to your drawing file.
Can you share your drawing then so I can take a look?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sorry for the late reply.
I had done the following to the font.
- its part of the logo.
- it required that the particular font had to be 75% of its original width.
- I did something (dont rem) to make that font look like I wanted it to be. Its still editable.
May be when I am printing now, the font is taking its original characteristics.
As a workaround, I brought the raster file of the text and filled it with solid hatch to get the required result.
Landscape Architect
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am using AutoCAD for Mac 2018 LT, the latest version.
Landscape Architect
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @earthsquare,
I am sorry for the delay but I just found your response.
Can you share a sample file with a pagesetup applied and your plot style too? Then, explain how you are creating the PDF step-by-step so I can make some suggestions.
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
