- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi James,
I looked at your AI file.
Let's try another DXF conversion way.
But at first you need to remove all special effects from the objects in your AI file using Illustrator: I noticed that for some reason straight lines with rounded corners in your AI file have Grain effect assigned:
1/ You have to remove this effect with Trash button. Then save AI file.
2/ Now in Finder change extension of your AI file from .ai to .pdf
3/ Launch AutoCAD and use menu File -> Import to import file you renamed in step #2
4/ Use standard settings in "Import PDF" dialog:
After importing PDF to AutoCAD you can save it to DWG and to DXF format. Just make scale adjustments with SCALE command.
I attached resulting DWG and DXF files I created in such a way for reference.
Maxim Kanaev
Architect
MARSS
