406 Vistas, 3 Respuestas
Problem on AutoCad 17 and 18 for Macs:  computer not highlighting polylines
Computer is not highlighting poly-lines selected when using the Area command to add lots of areas together.  This is very difficult because we cannot see which areas have already been selected, so risk repeating areas already calculated.  As a result, rather than being able to calculate all areas at once, we have to add to each area together manually, which is very time-consuming on large schemes with lots of different zones and areas to be calculated.
