en respuesta a: wei503
responding to  @Jorfeur and @wei503, in fact i'm using a clean tool (Dr. Cleaner) and it looks like if you clean the memory by using the cleaner it will sometimes make AutoCad crash.
Anyway after the support contacted me and explained what was the problem in my case, the crashes occur way less often, i would say they pretty much disappeared.
So i recommend @Anonymous to contact the support and let them have tests and see what's "wrong" whit your AutoCad.
Responding to @maxim_k, i work on it some hours a day, like from 2 to 6 hours a day. as i said before the crashes in my case tend to happen when i clean the memory while using AutoCad or when i've been working on the same file for a long time (like 4 hours) sometimes leaving it open and letting the mac go in standby mode.
Anyway the problem seems to be 90% solved to me, so i hope this post will help someone else fixing their problems.
Thanks for the support.
