luis-pl
1768 Vistas, 6 Respuestas
Create Solid 3D terrain on AutoCad Mac (from contours)
Hello friends,
This is my first post, I hope I'm not asking for too much. Smiley Happy
I am in need of some help, I've tried various solutions that failed and I hope you can give me a hand here.
I am trying to create a 3D solid out of contour lines that I have. I use Autocad for Mac, there is no way to generate the solid here. Solutions I've tried: exporting to Sketchup and using Sandbox tools, result is a mess, not solid and it just looks off; Also exported to Rhino and used 2 ways of generating the terrain, Patch and MeshPatch, one makes the terrain to soft and untrue to curves, the other made terrain to harsh and hard to manipulate, also, both meshes, not solids; Tried also the LOFT tool, but after selecting 2-3 curves the surfaces disappear, maybe geometry is too complex for LOFT.
After watching some tutorial I found that the DRAPE command creates nice 3D terrain solids but I can't install ACA, nor do I have access to PC, so I could do it myself.
I am in great need of this terrain, it has been 5 days trying to solve this with no success.
So, does any expert here have any equivalent solution of DRAPE for a Mac user?
I attached the file so you could have a look.
Knowing how to do this myself would be the best solution.
I also attached an image of the Rhino model I generated, I want something similar to that, but a little smoother.
Thank you very much! Emoticono feliz
 Luis
