- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Our company had been using BOX storage, but recently changed to Google Drive. Since then, Project Manager doesn't work. Previous project links are broken and cannot be updated.
When you "Add Existing Drawing..." within Project Manager, you still are able to navigate to the desired drawing and click "OPEN". Nothing happens. There's no dialogue in the Command Line, either.
If instead you click "New Layout..." within Project Manager, you are able to create a new layout based on templates. I've tried starting here and then changing the "Drawing Location" to my desired drawing as a work-around. From here I get a "Project Manager Error" which states "The following selected files do not contain any initialized layouts: /{file location}".
If I drag the the desired .dwg file to my desktop, Project Manager works as expected. This seems to be an issue with Google Drive. BTW, I did localize all of the drawings to my computer - but still sync'd with Google Drive.
¡Resuelto! Ir a solución.
