- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello friend
The trial software is no different than the software used with a paid license, other than it expires at some point.
You can save any drawing file and use a reader or other CAD software (such as BricsCAD perhaps?) to view and edit the same drawing file at any point down the road.
To view on *any* computer, you'll need some kind of CAD viewer, such as Autodesk DWG Trueview, or BricsCAD Shape, or Bentley View, etc. (Autodesk also has an online viewer, where you upload your DWG to them, then it displays in the browser)
You could also print the drawing to PDF if you just want to send the drawing to others who do not have a CAD viewer and don't want to install one.
Just keep the DWG file, because the PDF does not contain the same intelligence as the DWG file. It's just a print.
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
