maxim_k
en respuesta a: Anonymous
Hi Kristoffer,
I can reproduce the issue you described (I measured lineweights in PDF in Affinity Designer).
Lineweights are wrong when I "print" to PDF from Print window (using Preview in it, then saving PDF).
But, if I use Batch Publish with "AutoCAD PDF (High Quality Print)" preset, lineweights in PDF are correct.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
