en respuesta a: Anonymous
If a file cannot be opened, take the following steps, I hope it works under Mac OS
But sometimes even such detailed guides can't solve an issue, that's why for any reserve way you may see and learn following resources....
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA... - helpful article
https://download.cnet.com/Recuva/3000-2242_4-10753287.html - leading software, but I don't remember about its supporting of Macs
https://onlinefilerepair.com/en/autocad-repair-online.html - created for any OS, direct upload crashed .dwg to special envinronment
  • RECOVER command
    --Recovers a selected drawing file
    --If successful, open and run AUDIT command
    --Evaluates drawing integrity and possibly more error correction
    --Set system variable AUDITCTL=1 to create a report of audit results
  • RECOVERALL command (introduced in AutoCAD 2008)
    --Attached and nested xrefs are also opened, repaired, resaved, and closed
  • INSERT and EXPLODE
  • Start a new DWG with no template
    --Run INSERT and selected the corrupted drawing
    --Check the “Explode” option
