- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I got a 100Mb DXF file which seems to be a readapted STL 3D scanning as it is made of tons of small triangles and despite being on a quite new machine, the program frequently freezes.
Is there a way to replace all the triangles with a surface, possibly simplifying the drawing (I only need to split the elevons and modify the front cover of this delta wing plane?
Thank you
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi
If the model consists from 3D Faces , then yes, you can:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Conver...
But keep in mind that such operation can easily overload your Mac, so you can try to do the conversion by small parts.
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
thanks the solution is working but it totally freezes the PC even on a small surface. Is thee any way to simply the computational time?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Save it in DWG format, it should become much smaller in size.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
AutoCAD isn't that great at complex surfaces. You might be better off with Fusion 360 or a full-blown surface sculpting program for most, if not all, of such a process.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Giammarco,
I looked at your drawing and realized that @dgorsman was right - it is practically impossible to convert 3d faces that form the model into 3d Solids or Meshes in AutoCAD.
I used Rhinoceros for Mac to convert 3d faces in your drawing to 3D Solids, but at first I reduced meshes by 90% in Rhinoceros.
You can look at the result in attached drawings - Rhino export-solids.dwg - as it was exported from Rhino (solids)
and Rhino export-meshes.dwg - I converted solids, created in Rhino to Meshes to reduce file size.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you very much
Actually that's the only solution as the file is too complex to create a mesh
