05-05-2018
06:26 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-05-2018
06:26 AM
this is not working what you said i have 20 layout in 1 sheet when i am changing any drawing in model or layout it is all dimension are moving please sent me good solution in registered email
@pendeanwrote:
>>>...I usually dimension in layout space...<<<
If you move things around often, it appears you probably need to start changing your workflow processes to compensate, and dimension/annotate inside the viewport instead. It's the primary reason why annotative text/dims/blocks were created 10+years ago in AutoCAD.
I believe you seek DIMREASSOCIATE command.
