ChicagoLooper
en respuesta a: Anonymous
Ahhhh. I see your problem. Do this: While in Drawing 1, select the diagonal lines=>right-click=>Clipboard=>Copy with basepoint=>Click your desired basepoint (such as the bottom end point of the left line). Then go to Drawing 2, Right-click in an 'empty area" =>Paste. The copy command you are using only works when you are copying and pasting in the same drawing, such as doing both copy and paste in Drawing 1. If you want to paste in drawing 2, you need 'Copy with Basepoint.'
Chicagolooper
