2975 Vistas, 27 Respuestas
Paste problem
I want to load an element ( viewport or file ) on a project. So I copy the file with command+c and then paste the file on the project, but it doesn't work! It only shows the address of the file! What am I doing wrong here?
john.vellek has embedded your image(s) for clarity
imadHabash
en respuesta a: Anonymous
would you please restart your AutoCAD , then see if any changes ?
Imad Habash
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 I suggest exiting AutoCAD and then emptying the Windows Temp folder (type %temp% on the Windows run line to open the location in Windows Explorer)to clear the contents. This should clear the clipboard and hopefully  fix your copy/paste problem.
Please also try running an AUDIT and PURGE on your drawing file.
John Vellek
en respuesta a: imadHabash
nope! restarting didn't work!
en respuesta a: john.vellek
sorry I forgot to mention...
I have autocad 2018 installed on mac os high sierra varsion 10.13.4
I don't use windows :cara_de_decepción:
john.vellek
HI @Anonymous,
I'm sorry (and embarassed).  I looked at your image and was so focused on what you were highlighting that I did not pay attention to the Mac environment!
Here is a link for some suggestions for clearing out your clipboard on the Mac.  Please let me know if any of these steps resolves the problem for you.
John Vellek
ChicagoLooper
It appears you are trying to paste the 'name' of an AutoCAD drawing from a folder. Sorry, but you can't do that. You can xref that drawing into your current drawing or you open the drawing to be copied and copy to your clipboard (use a crossing window). Then in the target drawing, your current drawing, you paste the entities from you clipboard into the target's modelspace.
Chicagolooper
Clearing the clipboard did not fix the problem
Please help me
john.vellek
Hi @Anonymous,
Can you describe how you are performing your copy and paste? Are you using Command-C and Command-V? Have you tried selecting the geometry, rt-click and go to Clipboard to select one of the copy options?
Does that behave any differently?
John Vellek
ChicagoLooper
Ahhhh. I see your problem. Do this: While in Drawing 1, select the diagonal lines=>right-click=>Clipboard=>Copy with basepoint=>Click your desired basepoint (such as the bottom end point of the left line). Then go to Drawing 2, Right-click in an 'empty area" =>Paste. The copy command you are using only works when you are copying and pasting in the same drawing, such as doing both copy and paste in Drawing 1. If you want to paste in drawing 2, you need 'Copy with Basepoint.'
Chicagolooper
Unfortunately non of these things works...
Yesterday I unchecked the option " create new layouts in viewports" and it fixed my problem but today it's not working again!
I'm desperate!
john.vellek
HI @Anonymous,
If Copy/Paste is working properly in other applications then perhaps performing a Reset is in order to return AutoCAD to original settings.
John Vellek
ChicagoLooper
Are your diagonal lines on the "0" layer? From your jpeg, it looks like that layer is locked. Unlock it and try again.
Chicagolooper
maxim_k
Sorry, but there is no such option in AutoCAD.
What do you mean?
And, just for clarification - do you attempt to copy DWG file in Finder and then use Paste in AutoCAD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Preference in autocad
maxim_k
I see - "Create Viewports in layout", but not " create new layouts in viewports"
And what about my second question?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Have you tried to restart your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Yes but it doesn't work. It shows another address!
yes reset system but doesn't work
Copy paste action works in other apps except autocad. And i reset options.  Still not working
maxim_k
Do you have some clapboard manager application installed on your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
