- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have a problem with Autocad 2018 with my Mac, anyone can help? (Screenshots attached)
Thank you,
Vasco
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Vasco,
Do you have this problem from the beginning?
If it appeared suddenly, then: have you tried to relaunch AutoCAD? Restart your Mac? Reset AutoCAD preferences?
Which Mac model do you have?
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Maxim,
I got all these problems with my new Mac Book Pro (15-inch, 2017)
Mac OS Sierra 10.12.6
3,1 GHz Intel Core i7
16 GB 2133 MHz LPDDR3
Radeon Pro 560 4096 MB
Intel HD Graphics 630 1536 MB
Thank you,
Vasco
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
By the way,
I've reinstalled Autocad and cancelled Preferences, now I'm using Autocad 2017 but as you know I can't for example use the Flatten command as it is only on 2018 version...
Thank you,
V
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
One more info,
when I open a new file (acadiso) even if I'm on millimeters (Units) this is what I see (image attached)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
But in the attached image I see 2018 version. I don't see issue with grid in the image. Have you managed to resolve it?
2. >>>>even if I'm on millimeters (Units) this is what I see
I don't see anything strange in the attached screenshot. Everything seems to be OK with units - decimal with 4 digit precision.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Maxim,
I was mentioning units in mm just to explain that whatever I see on the screen (image attached) there is a kind of pixel shadow in the background of the polyline (like if it's in a different scale but it's not).
Tks,
V
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Do you use external display? I believe - yes. Isn't it?
Try to set system variable LINESMOOTHING to OFF.
Do you see glitches in this case?
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-2018-graphics-artifacts-on-an-external-...
The topic is in Russian Forum, the OP had the same problem as you with external monitor attached.
And here you can find solution for that topic, provided by Wei:
Or, you can try to play with LINESMOOTHING system variable I mentioned in my prev post.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Max,
I did verify and is a monitor problem, great! But if I can't upgrade now where do I find linesmoothing? Can't find it in graphconfig.
Tkss,
V
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Dear,
I found another trick, enable a two-view viewport and reduce one
I hope it can help as long as Autodesk fixes (I hope very soon) this bug.
Best regards
Delio
