dgorsman
en respuesta a: ptplans
Use point filters when selecting the destination point, so you can ".X" and ".Y" (or ".XY") to get the two ordinate values in the XY plane, then you can ".Z" a higher point if you have something to snap to.  If you don't, then you can select the destination point as "From...", pick the destination point, and then put in a relative location such as "@0,0,15".  Or, drop it into place then do a MOVE with the relative distance.
