1990 Vistas, 5 Respuestas
merge hatches
I have Autocad 2017 Lt for MAC. I am trying to merge 2 hatches but I can not find the way to do it.
Does anyone have any idea?
Thanks a lot.
maxim_k
en respuesta a: Anonymous
Hi Tania,
There is no such command in AutoCAD. On PC (not on Mac) and in Full AutoCAD version (not LT) you can use custom AutoLISP routines to accomplish such task, but not in LT for Mac.
The only one idea I have is to use "Recreate hatch boundary" option in HATCHEDIT command:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/learn-explore/caas/CloudHelp/cloudhelp/201...
You can recreate boundaries for hatches you want to merge in a separate Layer in order to simplify your work, then erase existing hatches and create them again (merged) with "Create separate hatches" on the Hatch visor option turned off.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Hi Maxim,
Thank you very much for your answer.
I was afraid that would be the answer.
Cheers
john.vellek
Hi @Anonymous,
I found this code from an older thread.  I apploaded it into AutoCAD 2018 for Mac and it allowed me to merge my hatches. Perhaps this is something that will work for you as well. If not, can you share with me the drawing you are working in with the hatches?
John Vellek
maxim_k
en respuesta a: john.vellek
Hi John,
OP has LT version of AutoCAD and unfortunately she cannot use AutoLISP routines in it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
HI Maxim - thanks for catching that!
John Vellek
