03-24-2018
01:17 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-24-2018
01:17 AM
Hi Bárbara,
1. Audit has found 462 errors in your drawing:
Total errors found 462 fixed 462
Erased 0 objects
But even after fixing those errors I as not able to save as PDF the 2nd and 4th Layouts in AutoCAD 2017 and in AutoCAD 2016 for Mac.
At the same time I was able to save to PDF those Layouts in AutoCAD 2018 for Mac and even without fixing errors in your drawing with AUDIT command.
Then I went further and have found that the case of the issue was in gradient hatch, which is visible in the 2nd and 4th Layouts. After I changed the type of the hatch to Solid (I assigned it red color in your drawing and attached this drawing to my post), I was able to save to PDF the 2nd and 4th Layouts in 2017 and in 2016 versions.
Maxim
Maxim Kanaev
Architect
MARSS
PASCOA_FINAL 2.dwg
4555 KB
