john.vellek
en respuesta a: Anonymous
Hi @marioplans,
I made a short video that walks through the steps to create a page setup. A page setup is where all your plot configuration is stored for a particular layout (or modelspace view).
In the video I show how the drawing is configured in Metric Units (mm).  I switch from modelspace to  a papespace layout.  This is ideally, the best place to print your drawings.  I start the page setup command and create a new page setup that adds the printer, paper size and orientation, scale, and plot style. I apply this to the layout I am working on. When I type PLOT (or use print or publish) the settings in the page setup should should up for the print job.
If you want to share your actual drawing file I can help you get it set up too.
Ad Dean mentioned, the Windows Snipping Tool is a great way to capture areas of your screen and even mark them up to indicate the area of focus.
John Vellek
