en respuesta a:
07:58 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-14-2018
07:58 AM
Posting the actual response of the support.
"As tested, the reported behaviour appears to be caused be the file format DWG 2007, which creates a large UNDO/REDO file when working or while saving the drawing.
To avoid this behaviour please consider to use a newer file format (e.g. DWG 2018) while working on existing drawings. If you need to exchange drawings with customers that use an earlier release of AutoCAD, you could down-save the drawing to the desired file format, before sending it to the customer."
