03-08-2018
07:34 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-08-2018
07:34 PM
Hi @kristinabhalter,
How do you check the autosave function? Please note the following tips:
- autosave will not be triggered until the savetime is up.
- the savetime is in minutes.
- default save path is under ~/Documents/Autodesk/Autosave/
- when savetime is up, autosave on Mac will not be triggered if autocad is keeping in a model dialog, or if no user action at all. Just run any command or select anything in canvas will trigger the autosave on Mac.
- also important to know that the existing autosaved files for a drawing will be removed once you save the drawing manually, for example, run qsave.
Wei Ma
AutoCAD QA Manager
