2358 Vistas, 19 Respuestas
AutoCAD LT 2018 FATAL ERROR: Cannot write to undo file probably disk full
while i'm working on AutoCAD LT 2018 on my Mac, with no particular reason this error shows up (FATAL ERROR:cannot write to undo file probably disk full).
So i've looked for solutions in this forum and i found something like empty the temp folder or disable the undo command. I tried to empty the temp folder and even then i still get the same error. i don't want to disable the undo command because i think it would be annoying to work without it.
I even read about some pan/zoom issues about this problem, i combined it by doing Undo-> Control->Combine->Yes and but it's not working either.
Is there really a solution for this error or do i just have to live with it? is there a setting to remove pan/zoom fro the undo command? anyone else have this problem?
Thanks for the support.
