merja.peltokoski
1456 Vistas, 4 Respuestas
Cuts and sections in AutoCAD for mac
I have tried to figure this out, but no... So I want to draw section and use section arrows. But I can't find those anywhere? So what is the solution for this? Do I have to just draw them or are they hidden in somewhere?
john.vellek has embedded your image(s) for clarity
pendean
en respuesta a: merja.peltokoski
Is that a solid 3D shape, or just a 2D rectangle?
maxim_k
Welcome to Autodesk Forums!
Hi Merja,
If you mean section arrows symbols, then plain AutoCAD doesn't contain ready made symbols.
You need to draw them yourself or find something suitable on the Internet (free or paid blocks).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
HI @merja.peltokoski,
AS @maxim_k indicated, you will have to either download some blocks from the Internet or create your own. If you need help in doing that let me know and I can try to assist.
If you are familiar with the Windows version of AutoCAD, you are probably looking for a feature such as Viewbase. Sadly that is not yet part of AutoCAD for Mac.  You can still however create this type of Geometry.  For Instance the rectangle can be drawn using BOX to create a 3D solid.  You can then use flatshot to create a 2D view of the plan view. Next, use Section Plane to "cut" the 3D solid.
When you move to paperspace you can now show a view of the flatshot you created, plus an iso or just the section of the solid.
Let me know if you have questions on any of these steps.
John Vellek
Thanks for the answers and help! I used earlier AutoCAD mechanical and in that program everything is automatic. But now I know, I have to draw those arrows etc.
