688 Vistas, 8 Respuestas
Display X ,Y, Z coordinates
I am new to AutoCAD and what I am trying is to extract X, Y, Z coordinates from the floor map drawings (.dwg). Can someone describe how can I display that information and if possible, export them in json?
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
If you are using full AutoCAD (not LT) you can use custom AutoLISP routine for this. With AutoLISP you can extract coordinate information of the specific objects in the drawing an write it at least to a text file.
In order to create such routine you should provide full information about objects whose coordinates you want to extract - are them points, blocks with attributes or something else?
You also can try to find ready made AutoLISP routine, but some routines written for AutoCAD for PC will not work in AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Thank you for your reply. I have a very basic question, though.
What is AutoLISP? You also mentioned finding ready made AutoLISP routine
but, routines written for AutoCAD for PC will not work.
Is there any other way then using AutoCAD to extract coordinates? I see the
coordinates in the bottom right.
maxim_k
>>>>What is AutoLISP?
Here is wiki article about AutoLISP:
https://en.wikipedia.org/wiki/AutoLISP
Can you share your sample drawing? I'll look at it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Most of the modern AutoLISP routines are based on Visual LISP functions (extended AutoLISP functions related to ActiveX support), which are not supported on Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
I have found AutoLISP file which works in AutoCAD for Mac.
It extracts coordinates from POINT objects and writes them to text file. In order to ensure that this routine will work for you I need one of your files to check what kind of objects you have in it.
Later I can explain how to use the routine.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Sure. I will send the floor map soon. Thanks!
Attached you can find the floor map. Look forward to hearing back from you.
maxim_k
Sorry, but you forget to attach the file to your last post.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
