10295 Vistas, 7 Respuestas
Scale drawing to 1:25 on A4
Hi there,
I am new to AutoCAD and trying to teach myself. I am having a confusing time with understand how to scaling a drawing and wondering if someone could help me.
I am currently trying to complete an assignment for an Interior Design course.
The project is a plan, drawn in millimetres. I need to scale the drawing to 1:25 on an A4 page.
My current settings are:
  • Units in model space to millimetres (See Image 1)
  • Scale in model space in 1:1
  • There wasn't a 1:25 scale in the menu so I created it (I think!) (Image 2)
  • When I switch to layout, I can see my drawing in the viewport but the viewport scale is 0.000790 (Image 3)
  • When I try to switch the viewport scale to 1:25, it zooms so far in you can no longer see the plan on the paper
Please excuse the unfinished plan but I just wanted to take some time to figure out how to scale it for printing.
I would be most grateful if anyone can provide help on where I have gone wrong and how to correct my settings.
Many thanks.
maxim_k
en respuesta a: Anonymous
Hi Rebecca,
Are you sure the plan will fit on A4 paper at 1:25 scale?
What exactly is the size of the plan in real world units (millimetres for example)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Hi Maxim,
I've been given survey notes of a living room plan. Everything has been measured in millimetres. (See Image 1)
Project is to draw up plan on A4 paper to a scale of 1:25 with a key and title block at the side.
Hey,
do you mean this?
Hi yes! That is what I need!
What settings did you do to get that? My plan seems to disappear when change the scale to 1:25
Please could you walk me through what you did?
maxim_k
It will fit.
Look for the answer (a kind of template for your plan) in the @
tekenbureauvanamersfoort reply.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
the position of the viewport is not always right above your drawn object in model space.
I first zoom out with zoom extent and then I go to scalefactor and then set the viewport to 1:25.
If the object is not completely within the viewport then you can use PAN to move the viewport.
Note: double-click in the viewport to use the Scale factor and Pan.
Then double click next to the viewport to go out.
Sorry for my English.:smileyhappy:
ben
Thank you for your help and replies.
Unfortunately, despite zooming out, setting the viewport scale and a lot of panning, I couldn't even find a wall as it seem to have enlarged so much. The only way I could see my plan at all was "scale to fit" which put the viewport scale in decimal points.
It only worked after I changed the page setup settings. For some reason, the scale there was set to something like 1mm = 0.0039 unit.
Once set to 1mm = 1 unit, the viewport scaled properly and my plan is now in 1:25.
Etiquetas (2)
