02-16-2018
07:05 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-16-2018
07:05 AM
Hello @twhitwell6
Although the issue is solved, there is a way to remove a layer even if it contains elements.
If you are sure of the name of the layer or you know you have an element in it and you want to delete it in all the forms, use LAYDEL; you can select a object in the layer to be deleted or, choose option NAME and in the window you select it, then it will ask you to confirm and it is ready! I will not leave remnants that you have to purge in that layer.
Postponed:
It works even with difficult layers like ASHADE or DEFPOINTS.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos!
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
