02-14-2018
09:44 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-14-2018
09:44 AM
Older versions of Autocad were not designed to be compatible with High Sierra. Therefore, 2016+ work because they were designed to be compatible with High Sierra. It may work but that is why it gives you the warning that it may be unstable.
This AKN explains it also:
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
